Jostrummer 0 Posted November 23, 2009 Report Share Posted November 23, 2009 Last month or so the power steering seems to have developed a whine when I go to turn, initially this was only when I first got car moving but is now more persistant. Any thoughts? I use the car every day, Colchester to Billericay and not had any real problems with the car so far. Link to post Share on other sites
VR6Pete 1,455 Posted November 23, 2009 Report Share Posted November 23, 2009 silly question, but have you checked the fluid level? Link to post Share on other sites
Jostrummer 0 Posted November 23, 2009 Author Report Share Posted November 23, 2009 no not a silly question I will do so....I will now ask a silly question..ahem.....where, roughly speaking should I look.....silly question' date=' but have you checked the fluid level?[/quote'] Link to post Share on other sites
VR6Pete 1,455 Posted November 23, 2009 Report Share Posted November 23, 2009 next to the washer bottle, thats behind the battery, but in front of the coolant expansion tank... it should have a green cap, but sometimes is black, if you follow the pipe from the PAS pump, it will lead to the bottle.Pete Link to post Share on other sites
Jostrummer 0 Posted November 24, 2009 Author Report Share Posted November 24, 2009 Thanks have now located where I should be looking. Will be investigating further today, assuming that it needs topping up can you advise the preferred brand I should use and how much do I need, is there a danger in overfilling for example? Many thanks for all your help.next to the washer bottle' date=' thats behind the battery, but in front of the coolant expansion tank... it should have a green cap, but sometimes is black, if you follow the pipe from the PAS pump, it will lead to the bottle.Pete [/quote'] Link to post Share on other sites
VR6Pete 1,455 Posted November 24, 2009 Report Share Posted November 24, 2009 I just got some pink stuff from my local car supply shop. I dont think there is anything special with regards to PAS fluid.There should be a guage attached to the lid of the bottle so there should be no danger of over-filling.Pete Link to post Share on other sites
NiNjaVR6 0 Posted April 11, 2010 Report Share Posted April 11, 2010 i think i have this problem..... iv topped up my fluid as was on min mark but its horrible .. whines with the revs, noise gets louder as steering is turned but still there stationery Link to post Share on other sites
void_main 0 Posted June 11, 2010 Report Share Posted June 11, 2010 I don't think power steering should whine when you rev the engine.If it whines only when turning the wheel, and you've already topped up the fluid then maybie your power steering pump has gone? I'm no expert.Also, the fluid in the system needs to be changed according to the service schedule, those fluids break down over time and become 'spongy'. Essentially its because its an organic compound, and when your using a fluid in a hydrolic situation, i.e. total force inputted in one end equals the same force outputted the other end you dont want the liquid to compress at all (which it can do once it starts to break down).If I've got any of this wrong, someone more knowlegable please correct me! Link to post Share on other sites
Rikki 2 Posted June 11, 2010 Report Share Posted June 11, 2010 You should only use the green stuff called CHF....halfords do it! Link to post Share on other sites
