mac110274 0 Posted November 10, 2009 Report Share Posted November 10, 2009 hi hope someone can help im a vw virgin and have been struggling to get info on the servicing needed for my vr6 basic engine and oils no probs auto gear oil no probs top up system a pain but not a prob had the car plugged in to a computer its telling me a charcoal filter needs changing ?????? what is it and were is it. next prob with it being 4 wheel drive does it have a transfer box connected to the auto box at the front i can see the rear trans box??? what oil do they take and if i remove the front drive shafts (they need new inner boots fitting) will the oil come out the local vw dealer is no help at all just told me "bring it in and we will sort it for you" yeah right can do these jobs myself have got pits and ramps at work for the forklifts and a bit of mechancal knowledge. lol!!! just need the information pleases help *-)*-)(i) Link to post Share on other sites
spindat45 0 Posted November 11, 2009 Report Share Posted November 11, 2009 Hi and welcome to the forum.According to my Autodata, the auto gearbox uses VW ATF (automatic transmission fluid) and takes 3.5 litres from empty. It also states that the front differential on an auto takes 0.8 litres. I've never seen or worked on one so I'm not sure if that forms part of the transmisson capacity or not. The rear diff uses 1.0 litre of 75W/90 synthetic oil but you may need to double check that as it does not specify a syncro.As for your drive shafts, again I've not seen a Sharan but on Golfs and Corrados, there are star headed bolts which allow the driveshafts to be removed without oil spilling out everywhere. Basically the part of the joint that goes into the gearbox stays in place once the star bolts have been undone. I can't say for certain but have a look around the inner CV boots for the star bolts and if they are there, you should be onto a winner. I hope I've made sense and been of a some help. Let us know how you get on.Kevin Link to post Share on other sites
mac110274 0 Posted July 25, 2010 Author Report Share Posted July 25, 2010 finally got round to changing the oils and the front transfer box is a stand alone unit a bit tricky to to top up though8-) Link to post Share on other sites
gavinvr6 0 Posted July 25, 2010 Report Share Posted July 25, 2010 sharan vr6 syncro? didnt even know these existed Link to post Share on other sites
