grayo94 0 Posted November 30, 2004 Report Share Posted November 30, 2004 had a diagnostic carried out on my 94 vr6 which came up with camshaft posistion sensor and crankshaft posistion sensor faulty, tried my local vw but all they have listed is knock sensor, speed sensor and hall sensor, anyone else had this and know what i need to ask for. any help much appreciated Link to post Share on other sites
bazz780 0 Posted November 30, 2004 Report Share Posted November 30, 2004 what are the symtoms of your car? hesitation in acceleration?? Link to post Share on other sites
grayo94 0 Posted November 30, 2004 Author Report Share Posted November 30, 2004 overfuelling and lumpy when cold, garage said will be running in limp mode until sensors replaced Link to post Share on other sites
acf8181 0 Posted November 30, 2004 Report Share Posted November 30, 2004 camshaft position sensor is the hall sender...you'll deffo know if thats screwed up as the car will a have significantly less bhp and will be really lumpy.i think crankshaft sensor will be the engine speed sensor. you will giet this fault code if the car was tested without the engine on, as it self clears once the engine is running.i'd phone them back to see if the car was tested with the engine on or off. also, were the faults intermittant or constant? Link to post Share on other sites
grayo94 0 Posted November 30, 2004 Author Report Share Posted November 30, 2004 was tested with engine on and off showed these faults both times, car has obeen overfuelling and dropping power over time, judders a bit at low revs and has lost about 25bhp on rollers, also pointed to lambda but they said that was prob because fuelling was screwed up by other sensors, will nip down vw and see if they have hall sender Link to post Share on other sites
bazz780 0 Posted November 30, 2004 Report Share Posted November 30, 2004 le tme know how much it costs and where its located, might need to look into that myself sooner or latercheers Link to post Share on other sites
grayo94 0 Posted November 30, 2004 Author Report Share Posted November 30, 2004 spoke to stealth, they gave me the part number so i could get it from local dealer, 32 quid plus vat. refreshing to find someone who offered to give me the part number without gaining any profit for themselves, will have to pay them a visit and get the car on the rollers to see if all is rectified. Link to post Share on other sites
mightyvr6 0 Posted November 30, 2004 Report Share Posted November 30, 2004 The crank sensor is big money though. If it was completely shot the car wouldn't start at all so it's worth checking the wiring and cleaning it first before comitting to a new part as it might be a poor contact. Link to post Share on other sites
acf8181 0 Posted November 30, 2004 Report Share Posted November 30, 2004 if you're 25bhp down then it does sound like hall sender.were the fault codes cleared, then rechecked again?so many guys don't do this, so how do you know it aint an old fault code?! Link to post Share on other sites
acf8181 0 Posted November 30, 2004 Report Share Posted November 30, 2004 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9889&item=4508417138&rd=1andhttp://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9889&item=4508343507&rd=1[ Edited Tue Nov 30 2004, 07:48PM ] Link to post Share on other sites
grayo94 0 Posted November 30, 2004 Author Report Share Posted November 30, 2004 was reset as i was in car at time and made sure of that, did three tests in total, same codes each time. seen that part on ebay, was gutted as just ordered it from vw earlier after stealth kindly hunted down the part number for me, Link to post Share on other sites
