I have recently popped on a few other sites for other manufacturers of cars and noticed somethiing...
Now we may have done this but either its not obvious or I'm daft... What am I talking about well the specs on the car, the history, the recalls, information on the standard gears/gearbox etc etc etc etc..
the reason I thought of this is that as the car is steadily making its way into the realms of history there is not an easy spot for those who are mising out to understand the car, our love and why it is unique etc etc etc
I have this information in my head. but there is loads more missing..
Engine
15-degree V6 cylinder DOHC
Alloy cylinder head, cast iron block transversely mounted in front.
Bosch Motronic fuel injection. (I think)
Capacity
Bore mm x mm
Ouput 174bhp at 5800rpm
Compression Ratio 9:1
Maximum Torque 171lb/ft at 4200rpm
Transmission
Front Wheel Drive
5-Speed (ratios here)
Reverse (ratio here)
Final Drive (ratio here)
Suspension
Front Independent with MacPherson Struts, lower wishbones, coil sprints and anti-roll bar.
Rear Semi-independent with trailing arms and track correcting bearings, torsion beam, coil springs, and anti-roll bar.
Steering
Rack and pinion PAS (Power Assisted Steering) Standard
? turns lock to lock
Brakes
Front 11in (288mm) ventilated front discs (but were smaller earlier and I dont know when they changed)
Rear 8.9in (226mm) rear discs (Ithink)
ABS Standard
Electronic traction control linked to front brakes
Tyres and Wheels
195/50 VR-15 on 6.5 x 15 - BBS Alloys (Standard)
Dimensions
Track - Front mm
Track - Rear mm
Wheelbase mm
Length mm
Width mm
Height mm
Unladen Weight kg
Performance
Top Speed - 145mph
Acceleration 0-60mph in 7.2 seconds
Overall mpg ( litres per 100km)
0-30mph
0-40mph
0-50mph
0-60mph
0-70mph
0-80mph
0-90mph
0-100mph
0-110mph
0-120mph
Max Speed - (claimed) mph
Standing qtr mile secs
Terminal speed mph
30-50mph in 3rd secs
30-50mph in 4th secs
50-70 in 5th
30-70mph thru' gears secs
Braking 70mph-0 ft
Test mpg
Equipment
Standard: Electric windows, alloys, front fogs and sports seats, MFA trip computer, tinted glass, and central locking. Electric metal sunroof, and central locking closing facility.
Insurance group - 18
Service interval - Every 10,000mls
Warranty - 1 yr, unlimited miles
What you get Central locking - yes (remote)
Radio cassette - yes
Electric windows - yes
Sunroof - yes
Alarm/immobiliser - yes
Leather - option
Alloy wheels - yes
Anti-lock brakes - yes
Airbags - yes
any way you see what I mean. I am sure there must be something we can borrow and refer to or fill in the blanks and add stuff as we go and add to the.... I dunno FAQ/buying guide section or something
Anyway lets be having your thoughts..
Now we may have done this but either its not obvious or I'm daft... What am I talking about well the specs on the car' date=' the history, the recalls, information on the standard gears/gearbox etc etc etc etc..
Engine
Capacity 2792cc
Bore 81.0mm
stroke 90.30
piston size standard 80.99mm
1st oversize 81.49mm
2nd oversize 81.99mm
piston clearences in bore(max) 0.05mm
Transmission
Front Wheel Drive
Suspension
Steering
Brakes
ABS Standard
Tyres and Wheels
205/50/15 VR (86 load) 6.5j x 15" bbs alloys
Dimensions
Track - Front 1413/1427 (depending which model)mm
Track - Rear 1434/1462 (depending on model) mm
Wheelbase 2475mm
Length 4020mm
Width 1695mm
Height 1425/1405 depending on model)mm
Unladen Weight kg
2dr/4dr 1155/1180
maximum laden weight
1680kg
unbraked trailer
600kg
bracked trailer
1200kg
Performance
Top Speed - 145mph
0-30mph
0-40mph
0-50mph
0-60mph
0-70mph
0-80mph
0-90mph
0-100mph
0-110mph
0-120mph
Terminal speed mph
50-70 in 5th
Braking 70mph-0 ft
Test mpg
Equipment
Sunroof - yes
Leather - option
Alloy wheels - yes
Airbags - yes
  • 3 weeks later...
