MarkGolf 6 Posted August 31, 2009 Report Share Posted August 31, 2009 Hi,On my LAST problem now, has had a new MAF, replacement ISV, coilpack and everything else is new as part of the rebuild but it idles like crappppp.. Possible air leak behind the MAF? Im 99% the engine is timed correctly but is that a possibility.. When the locking tool is in place, the crank pulley does line up..http://www.youtube.com/watch?v=A1W-Ps1my98VidHelp! Link to post Share on other sites
CALICO 130 Posted August 31, 2009 Report Share Posted August 31, 2009 have you got an exhaust fitted it sounds very noisy Link to post Share on other sites
MarkGolf 6 Posted August 31, 2009 Author Report Share Posted August 31, 2009 lol, yeah but the back end is in a garage and boot was open so it sounds super loud! Link to post Share on other sites
CALICO 130 Posted August 31, 2009 Report Share Posted August 31, 2009 have you had it on vag com to clear all faults Link to post Share on other sites
MarkGolf 6 Posted August 31, 2009 Author Report Share Posted August 31, 2009 Nope, I was under the impression that with OBD1 I could do literally nothing with VAG com...Couldn't be the timing could it, im sure it can't be but with my run of luck I wouldn't be surprised! Link to post Share on other sites
craggsy 91 Posted August 31, 2009 Report Share Posted August 31, 2009 You still can check faults out with it tho mate. Always worth running to check sensors are all good Link to post Share on other sites
MarkGolf 6 Posted August 31, 2009 Author Report Share Posted August 31, 2009 Will give it a go, hopefully save me buying things in trial and error! Driving me crazy! The only none new things are the lambda, throttle and cam position sensors, blue temp sensor, crank and air intake.. I've got a spare ECU, i'll give that a go too Link to post Share on other sites
VR6Pete 1,455 Posted August 31, 2009 Report Share Posted August 31, 2009 yeah it will idle like that if you've got an airleak behind the maf, I had the rubber not properly on over the throttle body from my intake once, couldnt see it at first. Link to post Share on other sites
