Hairyarse 0 Posted August 12, 2009 Report Share Posted August 12, 2009 Done a search and not found the answer yet - induction kit arrived today, its an FK Auto one. No fitting guide with it. Sure I can work it out but looks like there's too many pipes, clamps etc. Anyone got a pic of one fitted they can post up?Thanks in advanceAndy Link to post Share on other sites
Ben Seabrook 4 Posted August 12, 2009 Report Share Posted August 12, 2009 this one mate http://caraudiosecurity.com/shop/product/products_id/10338.html ? Link to post Share on other sites
Hairyarse 0 Posted August 12, 2009 Author Report Share Posted August 12, 2009 Thats the bugger Ben! As well as whats in the pic, there's a rubber tube, three clamps, two cable ties and a bracket which I think is for supporting the pipe, its the rubber tube not so sure about. Will have a play when got a mo, just dont want to cock it up! Link to post Share on other sites
craggsy 91 Posted August 12, 2009 Report Share Posted August 12, 2009 put pics up mate and we'll tell ya where it all goes. Rough inside diameter of rubber hose please Link to post Share on other sites
Ben Seabrook 4 Posted August 12, 2009 Report Share Posted August 12, 2009 well not had any experience with that kit tbh mate but in theory you just remove the standard airbox up to the MAF and then one pipe of your new filter should run from the MAF with a bracket which you can normally connect to the turret to the left and then the air filter fits onto the end. Cant really see why you would need any further piping clamps etc tbh ! Link to post Share on other sites
craggsy 91 Posted August 12, 2009 Report Share Posted August 12, 2009 Other clamps might be to hold a pipe to feed cold air to filter Link to post Share on other sites
Ben Seabrook 4 Posted August 12, 2009 Report Share Posted August 12, 2009 yeah but looking at the pic of the kit it doesnt look like the sort of filter you can run a cold air feed from mate. Link to post Share on other sites
CALICO 130 Posted August 13, 2009 Report Share Posted August 13, 2009 it might be the same sort of kit you get with K&N you have a metal bracket that fits between the maf and the airpipe then a peice of hose to connect that to the maf then the filter goes onto the maf then you have the pipe that is in the picture to funnel cold air upto the filter from under the inner wing or behind bottom bumper grille by the horn Hope thia helps can put a pic up of my K&N kit tonight if needed but its not on the car any more Link to post Share on other sites
Hairyarse 0 Posted August 13, 2009 Author Report Share Posted August 13, 2009 Nope, not a cold air feed one, will just be filter on end of pipe to replace the std filter box. Think will just open the bonnet at the weekend and try fathom it outThanks for the tips, will be interesting to see how many bits are left over when I've finished! Link to post Share on other sites
Hairyarse 0 Posted August 15, 2009 Author Report Share Posted August 15, 2009 Got it fitted nowDidn't need any of the flexible pipe, bracket etc - all seemed not to fit. Had to do some cable-tie bracketry though to stop it flopping aboutIt growls nicely now Link to post Share on other sites
craggsy 91 Posted August 15, 2009 Report Share Posted August 15, 2009 God dont let Ben see that mess on there....oh and Gav and Nat Link to post Share on other sites
Hairyarse 0 Posted August 15, 2009 Author Report Share Posted August 15, 2009 God dont let Ben see that mess on there....oh and Gav and NatLMAO, I did start to wipe it - hence the red patch in the middle of the gunk, but then thought CBA, wanna drive it! Link to post Share on other sites
