robbaker 0 Posted July 27, 2009 Report Share Posted July 27, 2009 Hi all, please help! My 'less than a genius' girlfriend was vacuuming the car out (who else! ) the other day and left the radio on for hours, running the battery out, thus cutting the power to the radio etc. I've tried the sometimes standard unlock codes of 0000 and 1111 but no luck and now its locked. Can I fix this and find out the real unlock code without me having to cross the VW garage with silver??!!!Thanks Link to post Share on other sites
craggsy 91 Posted July 27, 2009 Report Share Posted July 27, 2009 VAGCOM might be able to do this but i dont know for sure tho Link to post Share on other sites
VR6Rich 3 Posted July 30, 2009 Report Share Posted July 30, 2009 Code usually comes on a card inside the manual for the sat nav if you have it. Otherwise its a trip to VW sadly. Link to post Share on other sites
tmc482 0 Posted September 28, 2009 Report Share Posted September 28, 2009 When removed,the Nav unit will have a serial number stamped into the casing on one side, take this code to VW (with some ID, V5 just in case!!) & they'll get the correct code... doesn't take long. Then (here's the important bit!) you need to leave the ignition on to 2nd position, then turn the Nav on for about an hour... after this the unit will stop reading 'safe' on the screen, you'll be able to select the numbers to add the code again & all will be fixed! Driving the car with the Nav for an hour doesn't work... I tried! It has to be ignition on, & NAV on, also it can't be reset using VAG Com.... tried that as well! Hope that helps! Tim Link to post Share on other sites
