Bobtrude 0 Posted July 16, 2009 Report Share Posted July 16, 2009 When I drive down a long hill and I use my engine to brake im getting a hessitation when putting my foot down again. . . . . Link to post Share on other sites
matty.vrt 120 Posted July 16, 2009 Report Share Posted July 16, 2009 i no exactly what you mean the same happend to mine and it was a faulty lambda sensor have you tried vag com. Link to post Share on other sites
Bobtrude 0 Posted July 17, 2009 Author Report Share Posted July 17, 2009 yes, no vagcom error . Its anoying driving the car like this. Link to post Share on other sites
FishWick 21 Posted July 17, 2009 Report Share Posted July 17, 2009 That's always a good test when mapping. Overrun the engine for ages, and then floor it. What happens on a lot of cars is the mixture goes too lean for a moment, causing the hesitation.Usually a lazy lambda or bad mapping. Has it been remapped at all? Could even be a MAF issue or even a throttle issue if OBD2? Link to post Share on other sites
Bobtrude 0 Posted July 17, 2009 Author Report Share Posted July 17, 2009 its chipped by c2. It could be a lazy lambda because I havent heard about this before. . . . and theres alot of people using c2 chip. Is there any way to check the lambda? Link to post Share on other sites
Bobtrude 0 Posted July 19, 2009 Author Report Share Posted July 19, 2009 anybody? how do i check a bad lambda? Link to post Share on other sites
FishWick 21 Posted July 20, 2009 Report Share Posted July 20, 2009 Put a high impedance voltmeter across chassis ground and the lambda's signal wire (white I think) and when the engine's warm, the voltage should fluctuate between 0.1 and 0.8 V. If it's stable at 0.45V, it's either dead or still in warm up mode (need to do this when it's hot).I'd change the lambda anyway if you're in any doubt and only use a genuine one. Link to post Share on other sites
Bobtrude 0 Posted July 20, 2009 Author Report Share Posted July 20, 2009 thanks m8 Link to post Share on other sites
