v9f 15psi??????????
as with all these things if you need more you need more. but you are making a step up into the greather field of modifications when you go to stage 3.... if you join up as a premium member there a some threads on this...
membership is £15 and you'll save that on your insurance with the 15% discounts...
vf enginnering only makes a stage 3 set up 12 psi pulley to create 10 psi u can send your charger to america as the bearings are only good for stage 3 only u will def need to upgrade which will cost £150 plus shipping and u will have to get a custom pulley made as vf only make 12psi and no -more but it all depend who maps it as ns racing had a stage 3 vr running 312bhp mapped by a company in england i will not mention but then ns racing started working with a company, sls tuning in germany and they re-mapped and got 357 bhp and it pulls like a train
vf enginnering only makes a stage 3 set up 12 psi pulley to create 10 psi u can send your charger to america as the bearings are only good for stage 3 only u will def need to upgrade which will cost £150 plus shipping and u will have to get a custom pulley made as vf only make 12psi and no -more but it all depend who maps it as ns racing had a stage 3 vr running 312bhp mapped by a company in england i will not mention but then ns racing started working with a company' date=' sls tuning in germany and they re-mapped and got 357 bhp and it pulls like a train
45 hp difference with the same setup apart from the map????????
theres loads of threads on vortech about this iv tryed to find away of doin it for ages
its probly possible but iv been told even the ceramic bearings start to fail at 15 as the belt needs to be stupidly tighy as the drive pully would be tiny
gruven will make a custom crank pully ect with larger dimeters to you could run a bigger charger pully and still make 15psi but then you need a new belt and it still mite not even help much
or you could go for a toothed setup but thats 1400+
