john555 0 Posted June 15, 2009 Report Share Posted June 15, 2009 ok iv currently got a v9 on my car with everything setup for 12ps including a head spacer, i mite be able to da a swap for a rotax c30-94 with 14psi pully but im wondering if its worth all the hasslecan anyone advise me on wot they thing of there rotax chargersiewhat sort of power do these make at 14psiwould an engine with standard pistons take itatre these reliablewhat do they sound like (are they loud on tickover, do they still go silly loud at high rpm)my spec is obd2 2.8 vr6standard pistons compression spacerallard charge cooler any help would be great thanks john Link to post Share on other sites
spadam 7 Posted June 16, 2009 Report Share Posted June 16, 2009 Yea id also like to no the pro's and cons of a rotrex vs v9. Reliability, performance, ease to tune, tunning potential, prices of each of the 2 if anyone could help us be great. Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 Not had a V9 so cannot coment on that but i do have a C30-94 Rotrex charger running a 6psi pulley and have 280bhp. I just have a schrick inlet mani, flowed head and spacer plate. Tuning is quite easy with the rotrex really, just change pulley and poss add bigger injectors.I know cabrioman was running a V9 i think and was getting 292bhp at about 12-14 psi on a 2.9 engine. So less stress for me only running 6psi and nearly same power Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 As for sound they sound no different to any other charger on tickover, and all you hear at speed is the whoosh of intake and the usual whine.A very easy install really as you dont do anything to actual engine really. Like no tapping the sump for oil line. All you have to do is cut tensioner a little bit and possibly grind head a little bit, but that depends really. My original head didnt but flowed head needed to be ground back...well used a hack saw Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 14psi should see you easy over 300bhp as Storm say 10psi will get you 310bhp on a 2.9 Link to post Share on other sites
spadam 7 Posted June 16, 2009 Report Share Posted June 16, 2009 looks like rotrex is the way to go then. looke on storms website and its £2000 plus vat for stage 1. Craggsy how u finding traction at the moment. Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 no problems...but i dont boot it in 1st......but do in 2nd and not span wheels yet.....280 isnt massive really when charger can do upto about 400bhp Link to post Share on other sites
mike 6 Posted June 16, 2009 Report Share Posted June 16, 2009 no problems...but i dont boot it in 1st......but do in 2nd and not span wheels yet.....280 isnt massive really when charger can do upto about 400bhpim loving the sound of your charger craig, iv still not been in a charged vr, need to go out in one.shame they didnt make them very beefy looking like the v9.... Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 C38 rotrex chargers are bigger than mine. More room in bay to put other things tho with it being relativly small Link to post Share on other sites
spadam 7 Posted June 16, 2009 Report Share Posted June 16, 2009 so cragsy you reckon you can get 400bhp out of a charger. Whos the power band is it all high up 4000rpm and up or still feel strong down low. Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 Peak power on mine is around 5k mark. And yes 400bhp from a charger is very much possible. Ask vrsick mate all be it using a 3.2. But it is possible but will need stronger internals and cooling of some sort Link to post Share on other sites
mike 6 Posted June 16, 2009 Report Share Posted June 16, 2009 C38 rotrex chargers are bigger than mine. More room in bay to put other things tho with it being relativly smallso what kinda power do they produce, bet there not many of them going about second hand, altho yours was a rare pick up wasnt it, you saved about a grand didnt you? Link to post Share on other sites
john555 0 Posted June 16, 2009 Author Report Share Posted June 16, 2009 i mite give it a shot then sounds like itll b better than my v9 anyone no wot sort of power i shud expect for a rotax c30 94 in a 2.8 obd2 with 9:1 comp and a charge cooler running 14psi if its safe to do so on standard pistons n rods Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 Ring Storm John, they will tell you everything you need to know mate.Mike I saved about £600 from new and c38s can give upto 630bhp Link to post Share on other sites
john555 0 Posted June 16, 2009 Author Report Share Posted June 16, 2009 ill give him a ring tomorro cheers Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 Ive emailed em asking about pulley sizes and prices Link to post Share on other sites
john555 0 Posted June 16, 2009 Author Report Share Posted June 16, 2009 ah cool let me no wot they say Link to post Share on other sites
craggsy 91 Posted June 16, 2009 Report Share Posted June 16, 2009 Will do Link to post Share on other sites
Antihero1981 8 Posted June 18, 2009 Report Share Posted June 18, 2009 yeah but you need to think of other mods when going above 300bhp and also what boost your running...i got the v9 and on stage 2 i am running 290BHp with a few little mods......she runs sweet ,the noise takes a little while to get used to ......but if i put stage 3 bits on i can get over 300bhpcharge cooler is next on list for my stage 2 Link to post Share on other sites
john555 0 Posted June 18, 2009 Author Report Share Posted June 18, 2009 yer your setup was wot i was runnin last yer my cars all set for stage 3 now but im thinkin ill probly still not be hsppy with it so mite as well jst go straight for the rotax setupand i already have all the bits off my stage 2 setup, lower comp and a charge cooler so cant realy think of anything else ill need so im hopefully pretty much sorted aslong as my clutch holds up Link to post Share on other sites
RIX 0 Posted July 17, 2009 Report Share Posted July 17, 2009 20psi rotrex charger,fuck garret danish superchager rockshttp://videos.streetfire.net/video/supercharged-vr6-14bar_35921.htm Link to post Share on other sites
