Short shift kit!!
Not at all matey !
I tried to fit it once, and tbh it looked right, in the way that it looked liked the one already in there and that it would fit, but i couldn't get the old one out !
Its just a matter of removing the gear stick through the top (inside the car), held in by a couple of 13mm bolts and some split pins.
Then striping down the stick, and replaceing the pivot mech. with a new BnM pivot.
Fit it back in it`s hole, and play with the cable adjustment (at the gear box end, 13mm nut on the selector) untill it falls into gear smoovly...
Depends what you are like mechanicly, it should take you from 45mins to 1.5hrs...
The instructions are not very clear at all. They are a photo copy in american, which mine didn`t make much sense.... so be patient and use comon sense :)
  • 1 year later...
