R32 brakes are bigger than the 312mm TT ones though
I thought 4motions had the 312mm brakes and they came as standard with 16" wheels didnt they?
Yeh that's what i meant. R32 brakes are IIRC 334mm and require a minimum of 17" wheels therefore 312mm should fit behind 16's. But it does depend on the ET aswell. The fronts on my kerchers (et 20) with standard 288mm brakes have about an 2cm gap between the caliper and the wheel.
Ah sorry, misread your post!
