Can anybody tell me exactly what four wheel allignment is all about. How does it apply to a car like the golf? I understand how the tracking can be adjusted but don't see how the camber can be adjusted. I can see how changing the ride height would affect the camber/tracking but how do you compensate for camber?
im certainly no expert so correct me if Im wrong ;)
You can adjust the camber on the front wheels by the 2 bolts at the bottom of the shock absorber... I dont think lowering itself affects the camber but the fact that you have to undo those 2 bolts means that it goes out and needs checking after changing the suspension.
4 wheel alignment is best explained by someone else here
If you've just fitted uprated suspension to your car, a 4-wheel alignment is essential to get the best handling possible. Lowering the suspension changes the geometry, so camber and caster needs to be re-set.
There is a lateral (left-to-right) adjustment on the rear too. If your new wheels are rubbing on one arch only, getting the rear alignment re-set will probably sort it.
On a standard car it's only worth doing if you're getting uneven tyre wear, juddering, bad steering wheel alignment or general handling problems.
AmD are recommended - a very professional company and fair on pricing.
[ Edited Wed Feb 18 2004, 10:30AM ]
Hi, thanx for the replies. Thinking of uprating suspension to eibachs/konis, so just wondering what is absolutely necessary by way of allignment etc afterwards as there seems to be a huge variety in what people have had done and how much they have paid for it. My VR is lowered quite a bit from before I got it but doesn't handle particulary well. It holds the road very nicely but lurches arround and makes a huge fuss of reasonably minor road 'features'. I'm thinking that it probably has lowering springs but standard dampers which will have lost the unequal struggle a long time ago. Will fit the new setup myself and then get someone to check the allignment afterwards.
