Bobtrude 0 Posted April 1, 2009 Report Share Posted April 1, 2009 Ok, just had to ask since I have done a headgasket change. (dropped the comp to 8.5)I got cylinnder 1 to TDC.Checked the timing here: Made my own cam tool and slotted inn. Installed the gasket and spacer.Checked the timing on the crank pulley again. Wrapped the chain around the front camgear (so there was no slack) and then over the rear one. Cams where still where they should be. My question is:If the cams are slotted into place, AND the crank pulley is timed, AND there is no slack on the opposite side of the chain tensioner. Is the car now timed? Thanks:). Link to post Share on other sites
Bobtrude 0 Posted April 1, 2009 Author Report Share Posted April 1, 2009 bump Link to post Share on other sites
FishWick 21 Posted April 1, 2009 Report Share Posted April 1, 2009 Providing you didn't turn the engine whilst the cams were off, then yes, it should be timed.I would turn it a few times by hand and make sure it's still timed correctly. Also double check the intermediate sprocket timing marks are still OK. You can get a small mirror and light down there. Link to post Share on other sites
Bobtrude 0 Posted April 1, 2009 Author Report Share Posted April 1, 2009 Providing you didn't turn the engine whilst the cams were off' date=' then yes, it should be timed.I would turn it a few times by hand and make sure it's still timed correctly. Also double check the intermediate sprocket timing marks are still OK. You can get a small mirror and light down there.[/quote']Where is the intermediate sprocket mark? Is it the sprocket that the upper chain is connected to? Link to post Share on other sites
FishWick 21 Posted April 2, 2009 Report Share Posted April 2, 2009 You can only see it looking through a hole in the intermediate sprocket. Should be an arrow pointing north (or south). If it's pointing anywhere else, the sequential timing will be wrong and the injector end time will need to be corrected in the software. Link to post Share on other sites
Bobtrude 0 Posted April 2, 2009 Author Report Share Posted April 2, 2009 ok, think i located it in the "diy" changing chains and tensioners on vw vortex. http://forums.vwvortex.com/zerothread?id=1264409On nr 32. Thanks for the info:). Link to post Share on other sites
FishWick 21 Posted April 2, 2009 Report Share Posted April 2, 2009 Point 21 on this guide also shows the mark you can see....http://www.gruvenparts.com/website/diys/timing_chains_replacement.htm Link to post Share on other sites
Bobtrude 0 Posted April 4, 2009 Author Report Share Posted April 4, 2009 Thanks Link to post Share on other sites
MaidenVR6 26 Posted April 5, 2009 Report Share Posted April 5, 2009 How is this working for you? Have you started it up yet? Link to post Share on other sites
Bobtrude 0 Posted April 6, 2009 Author Report Share Posted April 6, 2009 Nope my trans is in the shop still and Im going away for easter so guess it will be finished when i come back . Gonna check the timing then. . . . many times! Link to post Share on other sites
jeffvr6 0 Posted April 11, 2009 Report Share Posted April 11, 2009 Hi, does anyone know the tricks of setting the timing on mk3 vr6. I did a headgasket change, new valve seals, head shaved. After I followed the installation proceder put everything back togather I started it up and it sounds like a diesel, (btw I never removed or touched the lower timing chain and sprockets). I then checked compression and #1-6 are not getting compression. I am totally stomped what could be the problem? Link to post Share on other sites
