Is there a guide for sorting thermo housing on here?
Just i need to replace mine and want as much info as pos before i break something!!
Also, looking at pics in the past, other ppls thermo housings seem to have 3 senors on. Red one closest to coil pack, then blue then yellow (cant remember order of those two!). What is the first red one for? Mine doesnt have that, just a blanking cap there instead :S
is very easy Ollie - take off the coilpack and should be obvious where the housing comes away from the block and the crack pipe -it's only three allen bolts to remove and then a few on the housing itself to undoe to get to the thermostat etc - just make sure you do it up tight and equally otherwise it won't sit tight against he block and will leak again :)
If I can do it anyone can !! ;)
Cheers chaps, will have a bash on tuesday hopefully.
Going to order Neuspeed thermostat tomoz along with parts from VW. Which leads me to my next question, what do i need? Dont mind replacing everything involved if thats the best option.
Part numbers would be great if anyone has these as well? lol
Dont ask for much do i!
