Ok, probably been asked before here goes.
Been running some 16's for a while and have managed to get a set of RS8 alloys which are 17's, they are currently fitted with 225/40/17 which gives an overall diameter of 612mm. My current 16's are fitted with 215/40/16 and this is an overall diameter of 578mm.
Problem is that i did originally have fitted some 205/55/16's which rubbed at the back and this was a diameter of 632mm. I have been looking and the best option would be 205/35/17 but i cant find any. Next would be 195/40/17 but again hard to find. The easy option is 205/40/17 but i am worried that they will rub as they give an overall diameter of 596mm.
Whats everyones thoughts? My car is on coilovers and is dropped at least 35mm at the back.
Do i need to fit spacers if so where can i get them? Whats the tyre recommendations??
Cheers
You should be ok with the 205/40/17's at that height and the wheel offset should be fine. I'm almost cetain it would be the same as the TT Comps which only rubbed slightly on mine when I had a lot of weight in the back. You could go with the 195's for a slightly stretched look to avoid that. Try http://stores.ebay.co.uk/Topgearshop_17-Tyres-Toyo-Yokohama_W0QQcolZ4QQdirZ1QQfsubZ9QQftidZ2QQpZ3QQtZkm. Very good prices especially on Toyo PX4's and next day delivery but probably not for the next couple of days. I've ordered from them a couple of times via their Ebay shop.
