leespeza 0 Posted January 18, 2009 Report Share Posted January 18, 2009 hi there, can anybody tell me how to drain the oil from the gearbox vr6 1995 2.8 as i havent changed it in 2 years also when my enigne is cold it hard to get 2 nd gear could this be because of the oil Link to post Share on other sites
SankysVR6 1 Posted January 18, 2009 Report Share Posted January 18, 2009 Moved you post as you will get a better response here.The drain plug is on the side of the gearbox. You will need a 17mm hex key to undo it, and its also the fill plug.I've picture of it on works computer so can post it up if you need me to.Also try doing a searh on here, as its been covered many times. Link to post Share on other sites
leespeza 0 Posted January 19, 2009 Author Report Share Posted January 19, 2009 hi again sanky if u could post the picture would be great thanks Link to post Share on other sites
darkstepper 0 Posted January 26, 2009 Report Share Posted January 26, 2009 Ive just changed mine I have a obd1 engine and my drain plug is at the bottom and the filler is located on the front of the gearbox (bumper side) make sure the car is not jacked up when replacing the oil else you may put it too much or too little Link to post Share on other sites
