Clutch conversion
I'm new to the vr tho so I have no idea where abouts I need to pull bumga from and what bits I will need to do the whole thing !!!!!
Cheers for the info grant !!! I'm just talking to guy from stealth about the immobiliser chip for my ecu so I'll ask about clutch too :-)
ill try and get u a pic up tomo mate as i had to do this on my cab ... but like Mr C2 said remove the rubber grommet from the bulk head and run the pipe up to the brake resivor ... ull need a mater cylinder pedal end, slave cylinder gear box end and pipe between the pair ..
