it will be an easy swap since you have both full cars, engine-box-clocks-keys-ecu-loom. done. well thats the idea anyway, as per golf girl should only be a weekends work, there is a guy in south london who can have you up and running in a day but he's gunna cost a few quid lol
You will have to change the pedal box as the 8v gti runs a cable clutch and the vr runs a hydraulic setup. I done my missus' gti/vr swap in a weekend, but if you havnt done this kind of swap before, it may take you longer.
By the way, dashboard will have to come out to change the pedal box and make sure you order the white clip for the brake pedal from VAG as they always break when you remove the pedal from the servo.
Also, as far as brakes are concerned, if you are uusing a late gti (96 onwards), they run a 288mm setup anyway, failing that, the 280mm setup will be sufficient unless you are planning on running big power....
Like these!! ;)
