Ford to Vw engine swap?
I don't know about the engine mounts but I'm running a Gallaxy/Sharan head on my Golf VR6 and the only difference is that the Gallaxy has SAI (Secondary Air Injection) like the yank cars. You'll need to remove the SAI stuff at the front of the engine and plug the hole witha 19mm core plug (freeze plug). Other than that I think you'll find there pretty much identical. The Gallaxy is OBD2 with the newer single timing chains.
The head parts, cams, valves, lifters etc all share the same part numbers. This also holds true for OEM manufactures such as Febi as there part numbers for cams, lifters etc are generic for all AAA motors. Also the quoted bhp for the ford is the same.
If there is any de-tuning it must be done via the ECU because mine absolutly fly's with the new ford head!!!
