I think i have a very slight coolant leak as my windscreen is always steaming up.
I have changed the pollen filter and cleaned out that area of leaves so its not that. It is always steaming up after i have been for a run and the car then steams up so it must be a very slight leak as it is not going through much coolant but there is a slight smell of coolant in the car. Also there are no apparent leaks anywhere and the carpets are always dry.
So i am thinking of putting some rad weld through the system to see if it stops it. Anyone else used this to cure the fault??
Cheers
Mark
if you're windscreen is misting up and you can smell coolant in the cab you're heater matrix is starting to leak. rad weld is only a quick fix/bodge as it tends to clogg the matrix giving you very little flow which is not very good if you don't like the cold. bung a new one in mate they're not bad to do!
