Edit: Help regarding permatex.
Hey there, sorry for such a abrupt post, but im about to put my cylinder head back on and have two questions, first is the arp studs, what are the torque settings for the nuts, i have been informed i should go with 85, but as this is the first time doing any thing like this i just want to clear it in my head. And then also what about the studs them selfs, how tight should i go with these? no locktight required I hope/imagine?
when putting a new head gasket on is permatex copper gasket spray neccersary? could i use the loctite version of copper gasket spray? it thas all the same heat specs etc. im using a c2 spacer sandwiched in between a victor reinz 3 layer gasket?
Thank you :)
Also just found out that permatex is made by loctite.
Is there not a sheet of paper telling you torque setting for both and sequence included with your ARPs? There should be, if not give the retailer a shoeing lol
permatex copper gasket spray is not needed but highy recommended. You might aswell wait till you got some as its not really a job you want to do twice
Never hurd of using locktight on headbolts... im 99.999% sure you don't have to
hey i done the search a few times, i hve found the answrs regarding the head bolts, but im stuck on the permatex, i can get hold of a loctite copper gasket spray, that has the same heat rating as the permatex, so would this be ok? want to get this head on today, its my only real chane.
well i managed to get some permatex with next day delivery, but ithe delivery was not cheap. lol.
when i spray this on my gaskets do i wait for it to dry, or do i put the gasket on when its tacky??
sorry for so many questions all the time, just wanting to get everything right.
