VR_6 0 Posted October 20, 2008 Report Share Posted October 20, 2008 hi,The water temptarure light on my vr6 started flashing yesterday. I started the car from cold and drove away, as i pulled out of the road a car was approaching fast from behind so i had to put my foot down. The engine was cold, straight away the water temp light ( red light most left of the cluster with a swiggly line and stick going down it) started flashing. It kept flashing so i stopped at the end of the road and turned the car off, when i started it again the light stopped flashing. the temp gauage was showing half as usual. car was running fine.When i got home i checked the oil which was fine, maybe a bit extra in there and the water was a liitle low but not too low. The oil cap had some white mayo type stuff on it. After it had cooled down i took the car fr a drive gain and the light stayed off, temp gauge was fine, reading on cluster showed 90-98 that was with driving it hard but the needle stayed in half.any ideas why the light came on? i think because i drove it a bit hard when it was cold, car driives fine and light is off now. will try it from cold in the morning.thanks Link to post Share on other sites
slim5878 1 Posted October 21, 2008 Report Share Posted October 21, 2008 mayo type stuff sounds live your head gasket is on its wat out Link to post Share on other sites
VR6Pete 1,455 Posted October 21, 2008 Report Share Posted October 21, 2008 How long were you driving the car for?short journies will always leave "mayo" on the oil cap, its just condensation forming...best getting it checked out for peace of mind though... Link to post Share on other sites
VR_6 0 Posted October 21, 2008 Author Report Share Posted October 21, 2008 i was driving it for 10 minutes Link to post Share on other sites
craggsy 91 Posted October 21, 2008 Report Share Posted October 21, 2008 What was oil temp as well....as engine need s to get upto opeerating temp every time you use it Link to post Share on other sites
VR_6 0 Posted October 21, 2008 Author Report Share Posted October 21, 2008 oil temp was low as the car was just started, but after a while it got to half. Link to post Share on other sites
VR_6 0 Posted October 21, 2008 Author Report Share Posted October 21, 2008 everytime i drive from cold for a short journey it leaves the mayo type stuff on the oil cap lid, does not use oil or water. water does not have oil in it either.When you drive it hard for longer journeys there is no mayo.how can i tell if the head gasket is gone, there aint no over heating either?thanks Link to post Share on other sites
craggsy 91 Posted October 21, 2008 Report Share Posted October 21, 2008 You've just said yourself why it gets mayo in filler cap matey.........oil needs to get upto temp to burn moisture off that has settled on oil. So in short ALWAYS get the oil upto at least 70 degrees Link to post Share on other sites
