charge cooler juice
Just use G13 coolant and de-ionised water in the charge cooler. Unless you mean Rotrex traction fluid which you can get from GMC' date=' TTS and Strom etc.
Lizard were do you get the G13 coolant as the charge cooler is your old one which I bought off CHRIS P
cheers
thanks for the info
spec is
2.8 vr6 obd2, 10.8mm ht leads with earth straps, audi s2 plugs, rotrex charger, lo comp plate, gas flowed head, saab 900turbo injectors 310cc i think? 10psi pully, samco hoeses, devils own aka aquamist running 50/50, k&n induction kit, 6 Branch Manifold, 2.5" De-Cat Pipe, 2.5" Exhaust, Removed Front Exhaust Silencer, Stand Alone Fuel Pressure Regulator, Maped By Storm Developments standered ecu at the moment
in the process of putting the charge cooler on. On the hunt for bigger injectors 440cc, stand-a-lone management in-line fuel pump
Chris hasnt done much as he is still in the build process i didnt see the car as i picked up the kit from his work place and he had his audi tdi estate with him he said its still in pieces
Keep us updated with the project Slim' date=' and those injectors where only standard 1's, Sorry i couldnt be any help Bud :)
no worries jake s*** always happens found a us site $60usd each 440cc so i think i may be ordering themhttp://www.bahnbrenner.com/vw_audi/products/634/42lb_High_Flow_Injector_440cc
Nice mate. I might be selling my injectors at some point but they may be to big for your needs unless you are going to run big boost.
i do want to run bigger boost i know i need to get standalone for that so let me know what you are after i take it its the 520's give me a call ricky 07846373431
