doxer79 0 Posted October 7, 2004 Report Share Posted October 7, 2004 Does anyone know if mk3 highline leathers would go into my late mk2? i have recardoz in there at the moment....if not how much of a mission is it to sort out?Cheers %-6 :! !dodge !ill Link to post Share on other sites
six appeal 53 Posted October 7, 2004 Report Share Posted October 7, 2004 Front is a bit of jiggery pokery and rear is even more hassle, best off selling the Highline interior and getting your Recaros re trimmed in leather with the money in my opinion. Link to post Share on other sites
1990 1 Posted October 7, 2004 Report Share Posted October 7, 2004 Its a piece of piss. The rears fit straight in but you'll have to knock something up as a centre bracket.The fronts can either be taken in by about 5cm on the runners or you can sit the mk3 seat base onto the mk2 subframe. Link to post Share on other sites
vdubgirl 3 Posted October 9, 2004 Report Share Posted October 9, 2004 As 1990 said yes its easy I put a mkIII cloth interior in one of my old MKIIs and if I (A girlie) can do I suspect you can. Only probs I came up against was with the rear bench the fitting aren't quite the same.Where the upper bench click into the upright position they dont click in very well to the fittings you have the in the mkII so a bit of force is requires and also the parcel shelf mounts may need shortening as the rear upper bench is a bit bigger/fatter than the origanal mkII and they wont click in the upright position properly if you dont mod the parcel shelf mounts.But with a few little mods you can get it to fit and the front seats are easy like 1990 said you need to change the sub frames and thats about it :-) Link to post Share on other sites
