ardandy 0 Posted August 4, 2008 Report Share Posted August 4, 2008 I've got a Corrado VR6 and am wanting to rebuild the engine (for various reasons!) for 2 main reasons;1, Reliabilty and long term longevity2, Preperation for stage 2 SuperchargeNow I've read that changing to low compression is recommended for s/c? I've also read that changing to low comp without a s/c is pretty crappy. As theres likely to be at least a year in-between the rebuild and the s/c, is a low comp necessary? I wouldn't want a poor Corrado for at least a year (if this makes sense).Am I better getting a 2.8 and reboring that to 2.9 than reboring mine? I've heard if I go bigger than 2.9 I could get issues due to the block been too thin??Would a stage 2 s/c (with recommended cooling stuff) be reliable with a properly rebuilt VR using standard components?Cheers! Link to post Share on other sites
matty.vrt 120 Posted August 5, 2008 Report Share Posted August 5, 2008 you could get forged standard compression pistons and if you want to lower the compression later use a thicker head gasket.although stage 2 dosent require the compression to be lowerd. people on hear recon the rods are good for 500 bhp so no need to change them.arp head and rod bolts may be a good idea for long term reliability.saying all that if its the vf engineering kit your talking about there made to run perfectly on a standard vr6. Link to post Share on other sites
xyber 1 Posted August 5, 2008 Report Share Posted August 5, 2008 Mines stage 2, everything standard and the recommended cooling mods and its fine Link to post Share on other sites
