MarkGolf 6 Posted October 6, 2004 Report Share Posted October 6, 2004 Can I simply replace that big mess with an oil breather as in the above pic?? Link to post Share on other sites
binliner 0 Posted October 6, 2004 Report Share Posted October 6, 2004 yesyou'll also need to block the hole in the big intake pipe and replace the small hose that runs from the manifold (near the TB) to the little valve thing (forgotten what its called) Link to post Share on other sites
acf8181 0 Posted October 6, 2004 Report Share Posted October 6, 2004 i wouldn't mount the filter the way it is in that pick, a friend did that on his mkII and it dripped oil onto the manifolds...not good. try and mount it upright.what little tube are you on about binliner? don't think it has anything to do with oil breather. neither does the ISV. Link to post Share on other sites
binliner 0 Posted October 6, 2004 Report Share Posted October 6, 2004 the little tube I mean connects to the oil breather... its the one that goes from the manifold, over the top of the breather with a bit that branches off and joins into it. does that make sense?I didnt mention the ISV! Link to post Share on other sites
binliner 0 Posted October 6, 2004 Report Share Posted October 6, 2004 oh the ISV is in the title isnt it! Link to post Share on other sites
acf8181 0 Posted October 6, 2004 Report Share Posted October 6, 2004 ok, that small hose must be an obd2 only thing, as i don't have one. the bigger hose that comes out the cam cover just goes straight to the intake. i believe mark has a 'rado obd1 engine, so all he needs to do is bung up the hole in the intake and pop on the oil cooler thingy.yep, the ISV bit threw me...whats that about mark? Link to post Share on other sites
binliner 0 Posted October 6, 2004 Report Share Posted October 6, 2004 oh and I attached my breather filter to a length of hose and run it out of the way so it wouldnt drip and to try and avoid fumes Link to post Share on other sites
MarkGolf 6 Posted October 6, 2004 Author Report Share Posted October 6, 2004 I duno what the ISV is about...Whats the big thing that is there for??I thought that was the ISV? Link to post Share on other sites
VR6Steve 0 Posted October 6, 2004 Report Share Posted October 6, 2004 That big mess is the engine! !amazed The lump on the end is a charger.Other than that I am lost! Link to post Share on other sites
acf8181 0 Posted October 6, 2004 Report Share Posted October 6, 2004 you can't see the ISV in that pic mark. Link to post Share on other sites
acf8181 0 Posted October 6, 2004 Report Share Posted October 6, 2004 ISV is circled- Link to post Share on other sites
MarkGolf 6 Posted October 7, 2004 Author Report Share Posted October 7, 2004 ah ok!!I always was told it hangs round the back of the inlet manhifold, and on my engine I have a mess of pipes there and a big thing and thought that was it!Stand corrected, cheers! Link to post Share on other sites
