Removing ISV/oil breather thingy...
i wouldn't mount the filter the way it is in that pick, a friend did that on his mkII and it dripped oil onto the manifolds...not good. try and mount it upright.
what little tube are you on about binliner? don't think it has anything to do with oil breather. neither does the ISV.
ok, that small hose must be an obd2 only thing, as i don't have one. the bigger hose that comes out the cam cover just goes straight to the intake. i believe mark has a 'rado obd1 engine, so all he needs to do is bung up the hole in the intake and pop on the oil cooler thingy.
yep, the ISV bit threw me...whats that about mark?
