93 CORRADO VR6 HEATER ONLY BLOWS HOT
  • 2 months later...
Not sure about non A/C golfs. However, there tends to be a metal cable....like your accelerator cable, pertruding from the rear dashboard into the engine bay. It leads to one of your coolent pipes going nto the dash...Heater matrix. It should be attatched to some sort of flappy valve.
This controls the heated water coming to and from the dash HM. Try pushing and pulling the valve with your engine warm and on.....also with the blower on and see if there's a difference
Push the valve all the way forward....go check the inside of the car for heat....then pull it all the way back.
Tell us what you find.
