The engine on my '96 VR seems really sluggish up to 4k rpm. I got overtaken by my mates 1.9hdi Peugeot today. Just doesn't seem to be as blistering as a VR6 should be. Could this be solved by some new plugs and replacing the MAF sensor or could it be something else, any help would be appreciated, cheers guys
Clean the maf with electrical contact spray, new plugs and leads,check the intake pipe isnt split etc
All things worth doing anyway, might aswel do the oil at the same time
If that fails, best to get it on vag com
BTW if you know someone with vag com so wont cost you anything do that first
you'll probably find a good service will sort it, VRs dont like old oil and can be sketchy with old plugs and leads
Check out the guide into cleaning the cam/hall sensor aswel in the downloads section
