VAG.com it mate, That will check all your sencers ect.
Also a blocked exhaust could cause the same kind of problem from a build up of back presure
Few things you can do that only take a few minutes
Is it well serviced? Have a little mooch at your air filter make sure its not blocked up
Also unplug your MAF... And go for alittle drive
Failing that get it on VAG.com as its the easyest way to see if you got a cam senser down ect
Is it well maintained? Know it sounds like a dumb arse question but you'd be surprised what passes for well maintained in this day and age.
Also seen a few threads like this already, might be worth checking your HT leads, especially if they're "high performance" ones.
