Non-Intercooled Turbo setups
Awrite folks
I'm wondering if it'd be worthwhile running a low boost non intercooler turbo set up with aquamist/methanol to keep inlet temps down as an alternative to a supercharger set up?
I'm looking for 300lbs/ft but cant afford a full on turbo set up with a solid bottom end. If you have any ideas or thoughts on this please post them up.
Thanks, Ken
Edit: I've seen a similar setup on a red Vento VrR6 turbo with a heavily smoothed bay but can't find pics at the minute.
PM'd C2 Motorsport.
That red one is actually intercooled I found a feature on it, its got a horizontally mounted Spearco intercooler just infront of the gear box, makes good power, 297bhp and 315lbs/ft of torque . . . at the wheels.
With how much boost? Take American whp claims with a pinch of salt.
Personally I would never run a turbo without an intercooler, but that's not to say it doesn't work. It does, but watch what happens to the power and torque after you've run it on the dyno 5 times, then compare it to the first cold run.
I've watched OBD1 take 17 degrees timing out on boost on a stage 1 kit (not C2's). It's just not worth it. If a job's worth doing....... even VW see fit for an intercooler on their 8psi 1.8T engines.
With the original intake, when i drive its ok, but if i stop the heat from the engine heats up the manifold and its noticiable less responsive and feels weaker. then when Ive driven some it cools down and is ok again . . .
Will get heat shield for the airfilter soon aswell. . . .
Motronic 2.9 has a very slow response time on the Intake air temp sensor, around 10 seconds to update. The poorly designed sensor itself heat soaks aswell, which can falsify the reading.
This means the air compensation map is pulling fuel and timing for longer than it really needs to.
VW addressed this on the 1.8T with an instant updating air sensor, but sadly it faults out to 70 deg C on Motronic 2.9. It only works on Bosch ME7 or standalones.
I take out 15% timing and 5% fuel if the IAT is 70 and it does feel a little sluggish until the intake cools down.
The fuel in the rail tends to bake when sat in the rail with engine off. Allow a minute or so for that to clear through aswell.
Some audis have fuel and / or fuel rail coolers :-)
