Damo 85 0 Posted April 18, 2008 Report Share Posted April 18, 2008 I'm looking to remove my engine plastics (lead holders, plastic engine cover etc) to re-spray them back to satin black as they are stained and nasty looking.I got the plastic engine cover and back lead holder out but the piece on the right of the engine as you look at it, and the front lead holder are stuck on by two big torx screws (star screws whatever you want to call them). unfortunately some muppet who last had the car has rounded them off and now i cant undo em.can anyone help with an idea to get these undone ??? well miffed off Link to post Share on other sites
Phat VR6 3 Posted April 18, 2008 Report Share Posted April 18, 2008 Drill the heads off.. Then mole grip the tread off. Weld a tiny nut ontop and use open end spanner (might melt cover). Butcher the cover off then use mole grips (ruff) Use a punch to tap it round. Good luck Link to post Share on other sites
Damo 85 0 Posted April 18, 2008 Author Report Share Posted April 18, 2008 cheers fella. had a feelin that might be the only way . might just try and spray them in situe if i cant get em off. its a lot of mucking about for me just so i can make them a bit more black than they are now!!!grrrrrrr. ta for the reply tho mate, appreciate it! Link to post Share on other sites
binliner 0 Posted April 18, 2008 Report Share Posted April 18, 2008 sounds like an extreme way of doing it!The right hand cover is held in by 2 spline bolts, I'd try and tap a larger sized torx bit in first and undo them that wayThe front one is held on by 2 screws which are underneath it and just slides off (might need a tap) Link to post Share on other sites
Caddymatt1380 0 Posted April 18, 2008 Report Share Posted April 18, 2008 If they aren't to tight you maybe able to cut a gouge in them big enough to undo with a flat bladed screw driver. Link to post Share on other sites
Damo 85 0 Posted April 18, 2008 Author Report Share Posted April 18, 2008 yeah good thinking... i'll have a bash with a bigger torx bit or try cutting in a slot for a large screwdriver.... ta fellas! Link to post Share on other sites
rodney 17 Posted April 18, 2008 Report Share Posted April 18, 2008 you have two main options here. If you can cut/lightly chisel a v in it then you can get a flat blade in to it an try and get it that way. the other thing is those gator do-hickies. lots of little spring loaded things in a socket that let you use it on unusual size/shape bolts etc.. (you know what i mean the toy that leaves a face imprint in it made up of nails)good luck Link to post Share on other sites
Damo 85 0 Posted April 19, 2008 Author Report Share Posted April 19, 2008 cheers guys! managed to hammer in a torx bit that was the next size up and crack them loose. they are all now repainted and fitted again! well chuffed!! Link to post Share on other sites
Caddymatt1380 0 Posted April 19, 2008 Report Share Posted April 19, 2008 You did replace the bolts didn't you? Link to post Share on other sites
Damo 85 0 Posted April 19, 2008 Author Report Share Posted April 19, 2008 didn't need to tbh... will do at some point, but the bigger torx bit actually made an indent for itself so i can just use that one for now! bonus. Link to post Share on other sites
Damo 85 0 Posted April 21, 2008 Author Report Share Posted April 21, 2008 here you go guys, not the best post but it'll give you an idea of what i took the plastic off for. hre is the engine when i got the car.. ewwwwand here it is now i managed to take off the engine plastics! Link to post Share on other sites
VR6Pete 1,455 Posted April 21, 2008 Report Share Posted April 21, 2008 sounds like an extreme way of doing it!The right hand cover is held in by 2 spline bolts' date=' I'd try and tap a larger sized torx bit in first and undo them that wayThe front one is held on by 2 screws which are underneath it and just slides off (might need a tap)[/quote']Thats what I did too, worked a treat, went straight to VW after to order a couple new ones.Pete Link to post Share on other sites
