Fran1664 0 Posted March 26, 2008 Report Share Posted March 26, 2008 I fitted splitfire plugs on my Corrado 2.9 1995 it was running fine i parked it come back half an hour later i started it heard a bang or missfire now it will turn over but wont idle i changed back to the orignal plugs but it did not solve the problem it will turn over and if i rev the engine a little it trys to run but soon dies any information would be appreciated Link to post Share on other sites
Devildub_06 0 Posted March 30, 2008 Report Share Posted March 30, 2008 Probably coincidence as your original plugs didn't work. Start with basic diagnostics like is there a spark at the plugs? (easiest way is to remove a lead at a time, put one of your spare plugs in, hold it against and earth with insulated pliers as you get someone to turn it over if it's a dizzy, if it's coilpack put spare plug in one connector at a time and repeat the above procedure), can you hear ticking from the injectors when turning over? Is the fuel pump running etc? Link to post Share on other sites
Fran1664 0 Posted April 1, 2008 Author Report Share Posted April 1, 2008 thanks for the reply the fuel pump is running the engine will run if i give it some revs but it dont sound healthy then cuts out when i stop i tried a new coil pack but it made no diffrence Link to post Share on other sites
cabrioman 6 Posted April 1, 2008 Report Share Posted April 1, 2008 yeah just sounds like a coincidence .....so it ran after u fitted the new plugs u left it then it all went funny yeah?? ... i had a smilaur thing and it was the hose on the throttle body had come / spilt .... just try basics to start with got fuel, air and spark .... Link to post Share on other sites
