xyber 1 Posted March 18, 2008 Report Share Posted March 18, 2008 Just found im losing loads of boost through my forge 007, its only been fitted for 1500 miles and seems the green spring has worn out already as it seems alot softer that it first did, so spoke to forge who are sending me a yellow spring to try and sort itHas anyone had this problem beforeWhat colour spring are you usingWhat psi is your charger runningWhere have you connected the vac line from the valve toThanks all Link to post Share on other sites
cadguy77 0 Posted March 18, 2008 Report Share Posted March 18, 2008 I'm using a blue on a 8psi pulley, no probs over the last year. Link to post Share on other sites
xyber 1 Posted March 18, 2008 Author Report Share Posted March 18, 2008 Ive just been out and had it apart and cleaned it up and the spring has definatly gone, really soft now and just spits out more air the more revs you give itPlus side is with the new spring in and full boost, it should be more fun again with that initial "woohoo thats better!" moment Link to post Share on other sites
xyber 1 Posted March 18, 2008 Author Report Share Posted March 18, 2008 I'm using a blue on a 8psi pulley' date=' no probs over the last year. [/quote']Thought I remembered you mentioning that back along Good rule of thumb then probably, your boost pressure x 2 (ie 8psi boost = 16psi spring) Link to post Share on other sites
Lizard Racing 0 Posted March 18, 2008 Report Share Posted March 18, 2008 I use a red spring now as the green one I had was leaking boost. Link to post Share on other sites
xyber 1 Posted March 18, 2008 Author Report Share Posted March 18, 2008 Ive been hunting around and it seems that a 6psi is its own force that it can exert on the piston/diaphram, so Its probably been leaking for ages and ive only just noticed now the weather has warmed up abit and ive got the windows open and heard the noisequote from the forge sitePlease Note:The quoted spring pressure (Psi) relates to the un-assisted clamping force of the spring and should NOT be taken as an equivalent to boost pressure when determining suitability. Once a valve is fitted to a car it is subjected to various pressures that act upon the diaphragm or piston to aid its respective ability to seal or hold boost. An example of this, would be when using a FMCL007P valve on a 1.8T engine as found in the TT 225hp. The boost pressure on a "chipped" car can peak at 26psi. The recommended spring would be the Green or Yellow Link to post Share on other sites
xyber 1 Posted March 24, 2008 Author Report Share Posted March 24, 2008 Problem solved, yellow spring to the rescue, getting a proper bit of dumpage now when letting off I get a bit of a pssshhh, where as before only got that when giving it some Wish I could go and try it out to see if there is an increase in boost but Ive done my back in, which is nice ;-( Link to post Share on other sites
cadguy77 0 Posted March 24, 2008 Report Share Posted March 24, 2008 glad you got it sorted Link to post Share on other sites
xyber 1 Posted March 24, 2008 Author Report Share Posted March 24, 2008 Cheers cadguy, just out of interest do you know how this valves workThey open off throttle to recycle the boost, but when your back on throttle do they close straight away or do they gradually close and then open instantly again off throttle?Mine seems to close gradually, although that is stationary and not under normal loads Link to post Share on other sites
cadguy77 0 Posted March 24, 2008 Report Share Posted March 24, 2008 under throttle the valve is closed by the spring, so when you come from off throttle/vacuum to on throttle/boost the valve should close instantly minimising boost leak thru the valve.Which way round have you installed your valve? bottom port to downstream charger side and side port to upstream charger side (if you get what i'm saying?)?? Link to post Share on other sites
xyber 1 Posted March 24, 2008 Author Report Share Posted March 24, 2008 yep, in through bottom port, out through sidevac hose connected to the spare port on the brake booster lineso the second you hit the throttle it should close and let no boost through? Link to post Share on other sites
cadguy77 0 Posted March 25, 2008 Report Share Posted March 25, 2008 That's the way i see it, but i'm no expert. The spring needs a fair bit of vacuum to pull the spring up (dependant on spring rating), so unless you're hoovering around the magic vacuum figure to pull your spring then it should clamp closed under any lesser vacuum/boost conditions Link to post Share on other sites
xyber 1 Posted March 25, 2008 Author Report Share Posted March 25, 2008 Ill just have to keep and eye on it I suppose, feels alot better, accelerating alot more aggressivly so im pleased with the fix, cheers for your help mate Link to post Share on other sites
cadguy77 0 Posted March 25, 2008 Report Share Posted March 25, 2008 NP Link to post Share on other sites
