Crankshaft Pulley
I assume these pulleys are secured vitha woodruff key as well (I could be wrong)
If this is the case then it will need to be replaced as well.
Also check slot for wear that may have been caused by chatter when pully loose.
Lightweight pulleys should be your last consideration as they offer no improvement at all.
IMO
