robvr6 0 Posted September 12, 2004 Report Share Posted September 12, 2004 how do these come off?tried unscrewing, the only clue seems to be 2 small holes on 1 edge of the cap, is there a tool required to get the off,car is a '93 golf vr6, not really sure what the wheels are call either so a bit vauge really sorry .... &| Link to post Share on other sites
DundeeDub 0 Posted September 12, 2004 Report Share Posted September 12, 2004 there is a tool but if you are careful with a screw driver or something like that you can get them off, or you can just pull very hard.another way would be to stick two small screw drivers down the holes and that might slacken the retaining spring Link to post Share on other sites
acf8181 0 Posted September 12, 2004 Report Share Posted September 12, 2004 can't you use the tool that should be in your tool kit in the boot (with the jack)? there's a tool for removing centre caps. Link to post Share on other sites
madmonkee 0 Posted September 12, 2004 Report Share Posted September 12, 2004 grap the nut thing both sides and pull it hard Link to post Share on other sites
DundeeDub 0 Posted September 13, 2004 Report Share Posted September 13, 2004 can't you use the tool that should be in your tool kit in the boot (with the jack)? there's a tool for removing centre caps.my bbs didn't come standard as i had the newer type but i prefered the older type so i bought a set a while back and didn't get a key with it. have just been pulling them off, or fot he tight ones pulling then helping with a screw driver Link to post Share on other sites
robvr6 0 Posted September 13, 2004 Author Report Share Posted September 13, 2004 thanks, made a puller from a metal coat hanger and black tape, Link to post Share on other sites
