Dragon6 0 Posted February 28, 2008 Report Share Posted February 28, 2008 Hi Guys my fuel pump seems to have quite a noisy high pitch whine/buzz to it,the car has done 64k miles comp standard runs/drives fine no juddering missing etc.Just wondered if this is normal or should I get it checked out.If it needs checking how do I go about this many thanks in advance.. Link to post Share on other sites
russvr6 0 Posted August 22, 2008 Report Share Posted August 22, 2008 my raddo vr6 also has a high pitch whine to it wonder if its the same problem let me know if you find out and vice versa Link to post Share on other sites
Bigjobbo 0 Posted August 28, 2008 Report Share Posted August 28, 2008 Mine does it when it's hot... sometimes. It's very common. I've queried this on several occasions and been told to put up with the noise and wait until it stops pumping fuel instead. Link to post Share on other sites
sixpotter 0 Posted August 29, 2008 Report Share Posted August 29, 2008 Mine also does this, completly standard 108k on the clock, also been told it may be the water pump bearing.Think im gonna book it in to stealth for a full check on everything tbh Link to post Share on other sites
