Roan 0 Posted January 26, 2008 Report Share Posted January 26, 2008 Apologies in advance for the length of this... :$ I recently modified my spare TB - polished internals, removed casting marks, knife-edged butterfly, opened butterfly full 90 degrees etc. I refitted it and reset the ECU (negative battery terminal disconnected for an hour). When I connected VAG-COM (I have a license) I got the following fault code (I expected something), so I set about the TB adaptation on VAG-COM as explained on Ross-Tech following the procedure exactly as here: http://wiki.ross-tech.com/index.php/Throttle_Body_Alignment_(TBA)When I went to the basic settings, I got an error in the four boxes, something like "Group 098 Error" and obviously the TB alignment didn't work. Any ideas - could the TB be faulty or have I missed something? *-) My car's now idling at anywhere between 1000-1500rpm, constantly hunting for a constant idle & it's driving me mad! :@ Saturday, 26 January 2008, 21:20:55VAG-COM Version: Release 409.1-SControl Module Part Number: 021 906 256 Component and/or Version: MOTRONIC M3.8.1 HS V02 Software Coding: 00000 Work Shop Code: WSC 013151 Fault Found:00533 - Idle Speed Regulation 15-00 - Adaptation Limit (Add) Not Reached Link to post Share on other sites
MaidenVR6 26 Posted January 29, 2008 Report Share Posted January 29, 2008 Try to re-adapt the TB with VAG COM.I needed to do the same on my VR this summer. Be sure to use a pretty new version off VAG-COM.Take's around 10 sec to do it:) Link to post Share on other sites
Roan 0 Posted January 29, 2008 Author Report Share Posted January 29, 2008 It's a faulty TB I think. Refitted my standard TB and the adaptation worked fine. Tried the modified one again, just connected it up without fitting and the same problem. The main return spring looks like it's loose in some way (when you shake the TB you can hear it's loose) and I really am notin the mood to dismantle it. I'll stick with standard for the meantime, although the modified one did make some difference, esp. to top end torque (stamping on the pedal in 4th/5th gear at 60-70mph was awesome!) Thanks MaidenVR6 for the reply though! Link to post Share on other sites
VR6Pete 1,455 Posted January 29, 2008 Report Share Posted January 29, 2008 ive heard bad things about the enlarged TB's, aparently too much air is let in around the butterfly when messed with, it causes irratic idleing. think eat this had that problem with one he had. Link to post Share on other sites
Roan 0 Posted January 29, 2008 Author Report Share Posted January 29, 2008 Yeh Pete, I think if you are going to modify, leave it at polishing and de-burring sharp edges. The problem is I spend too much time looking on Vortex for stuff to do to my car... that and finding new uses for the Dremel I got for Xmas... :-* Link to post Share on other sites
roodey 0 Posted March 31, 2008 Report Share Posted March 31, 2008 can someone tell me what the hell a (TB) is....??????? and im looking at alterring the throttle body to 90 degree s how do u do this??? im new to all this just for the record lol Link to post Share on other sites
Roan 0 Posted March 31, 2008 Author Report Share Posted March 31, 2008 TB = Throttle Body :$ My advice is leave it well alone. Give it a clean and maybe a polish then stick it back on. Never had as much trouble with a modified part before... Link to post Share on other sites
