SiGainey 1 Posted January 2, 2008 Report Share Posted January 2, 2008 Wanted to let you know about a great mod I did to the car over the xmas break - I installed the dieselgeek nylong shifter bushings. "These upgraded custom bushings replace the spongy black rubber bushing that is currently installed in the end of your stock front/back cable end. This mod was designed to make your A3 GTI/Jetta GLX or TDI and Passat shifter feel like the highly sought after MkIV Sigma shifter!"Installation took 15 mins MAX and only required a 13mm socket (unbolt shifter weight and end of shifter cable, push out old bushing with hands, place nylon bushing in cable end, re-assemble!). Full installation instructions can be found at step 19 onwards on the official site (http://www.dieselgeek.com/early_cable_short_shift_install.htm)The box now shifts into reverse a lot easier and is more precise in shifting between gears and the slight craunching into 3rd when I changed quickly seems to have disappeared too Will organise a group buy on these if anyone else is interested Link to post Share on other sites
ingham 5 Posted January 2, 2008 Report Share Posted January 2, 2008 im up for some how much are they?they look good Moderator edit by: SankysVR6 Link to post Share on other sites
SankysVR6 1 Posted January 3, 2008 Report Share Posted January 3, 2008 Just resized your picture Ingham,Sounds good how much are they normally? Link to post Share on other sites
SiGainey 1 Posted January 3, 2008 Author Report Share Posted January 3, 2008 Exact pricing is being confirmed, depending on numbers we can get - they are very light so postage is pretty cheap considering they are coming over the pond Think they are about 25 quid, well worth it Link to post Share on other sites
Karr-Man 0 Posted January 18, 2008 Report Share Posted January 18, 2008 yeah i would be interested in this, i get some crunching sometimes if i grab 3rd to fast Link to post Share on other sites
