Its easy to tell the difference by looking at callipers. Where brake hose joins them 280 mm has a flexi hose which screws straight into calliper whereas 288mm has a rectangle headed flexi hose with a seperate bolt to attach it to calliper just put steering on a full lock and get your head down in there and have a look allthough if your car is quite low you may have to take wheel off to check.
