Geastb 0 Posted August 19, 2004 Report Share Posted August 19, 2004 Would the complete brake set-up from an audi A3 1.8T (288mm disks) fit on a VR?Mine is the 280mm set-up at the moment Link to post Share on other sites
Joe M 0 Posted August 19, 2004 Report Share Posted August 19, 2004 I think the disks are a different offset so dont fit. Calipers carriers and hoses should be ok though. Link to post Share on other sites
Geastb 0 Posted August 19, 2004 Author Report Share Posted August 19, 2004 I might have to get them then! I want to go 312mm eventually anyway Link to post Share on other sites
Geastb 0 Posted August 20, 2004 Author Report Share Posted August 20, 2004 Before i order these can someone confirm that they are the same as later type vr brakes? Link to post Share on other sites
Geastb 0 Posted August 23, 2004 Author Report Share Posted August 23, 2004 Can anyone help? Link to post Share on other sites
acf8181 0 Posted August 26, 2004 Report Share Posted August 26, 2004 i reckon the discs will be different offset, and that the caliper will need spacering out....but i may be wrong. only one way to find out. Link to post Share on other sites
Joe M 0 Posted August 26, 2004 Report Share Posted August 26, 2004 Yeah, the 288 setup will fit fine as long as you use the late mk3 vr disks. If you go for 312 then the offset is wrong so u need spacers. You could probably use the same spacers for the 312 disks to fit mk4 288 disks. Link to post Share on other sites
