VR6Pete 1,455 Posted August 15, 2004 Report Share Posted August 15, 2004 Went to start my car this morning.... and it started spluttered and cut out. when i put me ignition on auxilery my oil light flashed 3 times and stayed solid, but when the car did start 2nd time round it didnt flash in auxilery and went out as soon as it started. it was quite a damp morning at 7am... does anyone know what this could be?Pete Link to post Share on other sites
VR6Pete 1,455 Posted August 20, 2004 Author Report Share Posted August 20, 2004 come on guys, any idea's? Link to post Share on other sites
jcorallo 0 Posted August 20, 2004 Report Share Posted August 20, 2004 When you first turned the engine over, there was no oil in the system (all drains back to the sump overnight), hence the flashing light, so it takes longer to charge the system with oil.Second time you tried to start it, you'd allready just primed the system with oil, so the light went out quicker as it built pressure quicker.Jules Link to post Share on other sites
tandino 1 Posted August 20, 2004 Report Share Posted August 20, 2004 Cutting out was probavbly due to the hydraulic tappets having no pressure and therefore not opening the valves...How long since the car was used prior to having the starting problems? - seems strange if it was only a day or so?Pete. Link to post Share on other sites
VR6Pete 1,455 Posted August 20, 2004 Author Report Share Posted August 20, 2004 it was parked for 12 hours. as i was at work... it's happened a couple of times now... but only when it's early in the morning and damp... Link to post Share on other sites
