Hella Mk3 Golf LED 'Celis' Headlights Supplier
As it turned out, i didnt need the wiring harness! Lucky i guess. But apparently there are two conenctors found on the VR6. If you already have the oval type then you will not need the adaptor. If you have the square connection you will. However I have a wiring harness at home and could sell you this if you were to buy some lights?
