Scotty 0 Posted August 6, 2004 Report Share Posted August 6, 2004 Ok My newly acquired Vento Vr6 does'nt give me much confidence in it's brakes.Just wondering what setup up you run standard brakes on it at the moment (Thought about Grooved Disks) %-6 Link to post Share on other sites
acf8181 0 Posted August 6, 2004 Report Share Posted August 6, 2004 if its and obd1 (upto, and inc, M plate) best upgarde is to fit later obd2 (N plate on) brakes. obd1 had 280mm, obd2 288mm.performance discs and pads are only worthwhile if you have brake fade problems, as they are worse when cold. Link to post Share on other sites
Scotty 0 Posted August 6, 2004 Author Report Share Posted August 6, 2004 Its a 1997 P-plate Link to post Share on other sites
acf8181 0 Posted August 6, 2004 Report Share Posted August 6, 2004 288's are normally quite good...have you checked the condition of the discs and pads? and are they bled properly (is the pedal squishy)?you can upgrade to 312mm if you have 17" wheels. (TT carriers, spacers, TT discs, and your existing calipers) Link to post Share on other sites
andy 0 Posted August 6, 2004 Report Share Posted August 6, 2004 if you fit the 288mm discs, is that all you have to do? what i mean is do you need later calipers/different pads etc....?[ Edited Fri Aug 06 2004, 08:35PM ] Link to post Share on other sites
acf8181 0 Posted August 6, 2004 Report Share Posted August 6, 2004 if you fit the 288mm discs' date=' is that all you have to do? what i mean is do you need later calipers/different pads etc....?[ Edited Fri Aug 06 2004, 08:35PM ']ok, not sure i totally understand what your asking, but...the early cars have 280mm calipers, which are different to the later 288mm caliper ...but the 288 calipers can be used with 312mm discs once you get the 312 carriers and a spacer on. Link to post Share on other sites
andy 0 Posted August 6, 2004 Report Share Posted August 6, 2004 ok, what i meant was, i have an earlier car, what would i need to change to have the later type brakes, is it disks/calipers/pads? Link to post Share on other sites
acf8181 0 Posted August 7, 2004 Report Share Posted August 7, 2004 calipers, carriers, discs, padsand maybe front brake hoses as well (not sure)[ Edited Sat Aug 07 2004, 09:46AM ] Link to post Share on other sites
andy 0 Posted August 7, 2004 Report Share Posted August 7, 2004 ok cheers, are they significantly better than the early ones? i've got no major complaint with the early ones but bigger would be nicer, its not a light car! Link to post Share on other sites
mark@vagworx 0 Posted August 9, 2004 Report Share Posted August 9, 2004 Haven't driven an early VR to know what the brakes are like.......but mines got 288's and they really do inspire me with confidence.....like you say it's a heavy car. Link to post Share on other sites
acf8181 0 Posted August 9, 2004 Report Share Posted August 9, 2004 i'm the opposite of minty...never driven a 288 equipt vr6! Link to post Share on other sites
mark@vagworx 0 Posted August 9, 2004 Report Share Posted August 9, 2004 I don't exactly hang around when driving, and i tend to brake VERY late for roundabouts etc etc......and like i said before i really can't fault them. May upgrade to 312's at some stage.....but more for the sake of having bigger brakes behind the rims....pure posability really! Link to post Share on other sites
acf8181 0 Posted August 9, 2004 Report Share Posted August 9, 2004 mine are ok at high speeds now i have FR pads (used to overheat before)...but they lack low speed bite. Link to post Share on other sites
mark@vagworx 0 Posted August 9, 2004 Report Share Posted August 9, 2004 Mine are good at low speeds too Link to post Share on other sites
andy 0 Posted August 9, 2004 Report Share Posted August 9, 2004 what pads you using minty? Link to post Share on other sites
acf8181 0 Posted August 9, 2004 Report Share Posted August 9, 2004 Mine are good at low speeds toothink thats the biggest advantage of 288's.also, i bet fade isn't a prob so you can stick with o.e. pads (and thus not sacrificing cold performance)i'm upgrading to 288's when i next need pads. Link to post Share on other sites
mark@vagworx 0 Posted August 9, 2004 Report Share Posted August 9, 2004 what pads you using minty?To my knowledge they're standard pads, fairly sure they're not uprated. The whole setup feels really good. Link to post Share on other sites
apd 0 Posted August 23, 2004 Report Share Posted August 23, 2004 so without sounding stupid,if you've got a 94M [280mm disks].to upgrade to the later system all i would need is 288mm disks and pads to match,without the calipers? Link to post Share on other sites
andy 0 Posted August 23, 2004 Report Share Posted August 23, 2004 apdacf8181 said"calipers, carriers, discs, pads and maybe front brake hoses as well (not sure)" Link to post Share on other sites
apd 0 Posted August 23, 2004 Report Share Posted August 23, 2004 288 disks would foul the original 15s,as disks are shagged i'll fit new disks and pads all round to improve heavy braking at speed. Link to post Share on other sites
acf8181 0 Posted August 26, 2004 Report Share Posted August 26, 2004 well, i know that 15" solitudes fit over 288's as highlines came with them, so do gti long beach alloys (have tried one on a mates highline), and the late bbs cross spokes obviously would to.only question marks is the early cross spokes (sort of dished ones) Link to post Share on other sites
