amazak 3 Posted July 8, 2007 Report Share Posted July 8, 2007 Hello Everyone,I have just won a excellent set of wheels but they came from a Subaru, 5x100 ET55, I was wondering if the ET measurement will be a problem?Thanks Link to post Share on other sites
VR6Rob 0 Posted July 8, 2007 Report Share Posted July 8, 2007 you will need to space them out a bit and the bore size is 1mm smaller then the VR6 Link to post Share on other sites
amazak 3 Posted July 8, 2007 Author Report Share Posted July 8, 2007 I am sure the bore can be adjusted but what do you mean by space them? Will the wheels be to close to the springs?Thanks Link to post Share on other sites
VR6Rob 0 Posted July 8, 2007 Report Share Posted July 8, 2007 the vr6 et is 35mm so you will need spacers to stop them hitting the spring Link to post Share on other sites
amazak 3 Posted July 8, 2007 Author Report Share Posted July 8, 2007 Ok, I see what you mean, so basically the higher the ET the closer the wheel gets to the suspension, also are these 'spacers' safe?Thanks Link to post Share on other sites
Toby 0 Posted July 9, 2007 Report Share Posted July 9, 2007 I just 'spaced' my porsche wheels (ET55) with H&R hub adapters and are fine - I got my adapters from Europerformance.co.uk, £220 delivered (which is the best price I could get). I got 25mm adapters, but you can get a larger width - the larger the width the more the wheels will stick out from the car, but you need a minimum of the difference between the 2 offsets (VW and the Subaru) - i.e if the difference is 20mm (35-55), then you need at least a 20mm spacer. Hope this helps - I found it quite confusing before I did mine, so if you need to know anything else just shout! Link to post Share on other sites
amazak 3 Posted July 9, 2007 Author Report Share Posted July 9, 2007 Ok, that is expensive, won these wheels of ebay for £41, but the owner decided he is going to charge me £60 incl packaging and paypl charges, furthermore I have to pay another £35 for courier service, then another £150 for tyres, and now a further £200 for adapters...hhmmm, I might as well just get the 17" TT COMPS instead. Btw these are 15's but they sure look good, should I take them? Link to post Share on other sites
Toby 0 Posted July 9, 2007 Report Share Posted July 9, 2007 well that's personal preference - to me 15's are just a little bit small, but then that's my own preference. They're nice looking wheels though. bit different from the comps which is good... Link to post Share on other sites
stusnook 0 Posted July 9, 2007 Report Share Posted July 9, 2007 in my opinion - thats too much ££ to spend on some 15s (when you add up postage, spacers etc etc). But all down to personal preference.Note: I'm running the original standard 15s with standard suspension on my VR6 at the moment, and if I change it would have to be to go to 16s at least, if not 17s. BUT I wouldn't change wheels without dropping the suspension too - 'cause it looks so much better when its been dropped 35mm or more. Link to post Share on other sites
Toby 0 Posted July 9, 2007 Report Share Posted July 9, 2007 this is the problem I have at the moment - have the wheels but not lowered yet and looks way too high! Suspension will be coming as soon as funds allow! Link to post Share on other sites
amazak 3 Posted July 9, 2007 Author Report Share Posted July 9, 2007 Yeah, guy's you are all right!, Why bother spending all that money, maybe if they fitted straight on then it would have been cool, I am going to pass, maybe consider 17's?? Hopefully will have the car lowered soon, that will helpmake a decision as I am not sure how low it might end up Link to post Share on other sites
SankysVR6 1 Posted July 9, 2007 Report Share Posted July 9, 2007 They look very simillar to the Corrado speed lines, which would be a direct fit for the VR, and thers ushally loads on ebay.Just keep looking mate Link to post Share on other sites
