francovr6 0 Posted June 20, 2007 Report Share Posted June 20, 2007 I brought my v6 golf into ireland a month ago from manchester and brought it to mechanics for the once over. Too my shock he told me head gasket was fooked. I noticed I had to refill the coolant resevoir to refill level from about half full after about 500 miles of driving. I can see i am loosing water from the thermostat housing a common problem i have read about thanks to this site. I have no oil in my coolant, or water on dipstick, i also have no problems with temperature as car runs nearly at constant 90 degrees when warm. The car can sometimes be unresponsive low in the revs and then after a slight knocking noise it takes off. could this also point towards head gasket. Any advice would greatly be appreciated as iv had 3 "mechanics" look at it and none of thes could give me a straight answer. Link to post Share on other sites
philtvr 0 Posted June 20, 2007 Report Share Posted June 20, 2007 I would start by replacing the thermostat housing as is knackered anyway then monitor water usage again. Garages can do a test for exhaust gas in the the coolant so ask for one of those but try to be there to see the result. If it comes back clear there still is a chance it has gone though.The unresponiveness could be an air leak so check all the pipes are on properly and the clips are tight. Link to post Share on other sites
mombajomba 0 Posted June 20, 2007 Report Share Posted June 20, 2007 New thermo housing is about 30 from VW. Use a good allen key though, those things strip too easy. I had to angle grind one off in the end. Link to post Share on other sites
francovr6 0 Posted June 20, 2007 Author Report Share Posted June 20, 2007 cheers guys Link to post Share on other sites
xyber 1 Posted June 20, 2007 Report Share Posted June 20, 2007 get a 160oc thermostat from awesome gti whilst your tinkering in that area aswel, only about £17, but worth while for keeping the temp down a notch Link to post Share on other sites
VR6BOY 2 Posted June 20, 2007 Report Share Posted June 20, 2007 Whereabouts in ireland are you living i have a spare motor its a ABV corrado 2.9 Link to post Share on other sites
francovr6 0 Posted June 21, 2007 Author Report Share Posted June 21, 2007 longford unfortunately. hopefully i wont need that engine ur talkin bout though Link to post Share on other sites
VR6BOY 2 Posted June 21, 2007 Report Share Posted June 21, 2007 hopefully, but its there anyways Link to post Share on other sites
francovr6 0 Posted June 21, 2007 Author Report Share Posted June 21, 2007 nice one we will see what happens dude Link to post Share on other sites
