Geastb 0 Posted May 24, 2007 Report Share Posted May 24, 2007 My sunroof no longer closes when holding the key in the locked postion, nor does the full closure on alarm close it? It does work when using the switch - can someone point me in the right direction to find the fault? Link to post Share on other sites
SankysVR6 1 Posted May 24, 2007 Report Share Posted May 24, 2007 are all other door windows working fine with switches.I think you can proramme it buy switching the ingition on with drivers door open and open and close all the windows one by including the sunroof.Switch off the ignition and then lock all the doors with key and hold it for a few seconds, and then open the locks and hold it until the windows and sunroof open and lock again and close windows.and that should sort it out, have you disconnected the battery before the fault happened Link to post Share on other sites
