VR6gaz 0 Posted May 13, 2007 Report Share Posted May 13, 2007 My mate has a mk3 16v GTI which today for some reason wouldnt go in to 1st, 3rd, 5th or reverse gear?!?!?!?!?it goes in 2nd and 4th fine thoughany ideas wot the problem could be? Link to post Share on other sites
cabrioman 6 Posted May 13, 2007 Report Share Posted May 13, 2007 could be a selector fault try operatiin the selector by hand (with out the engine runnin ) and see if u can get the gears if not then mite need to have it looked at by a gearbox spelist if u can then u mite just have a cable or gearstick box problem Link to post Share on other sites
craggsy 91 Posted May 13, 2007 Report Share Posted May 13, 2007 I had this problem not long ago. It wasn't till I had a proper look thro' all the grease on the mech that I found this peice broke on mine As you can see it holds the cable which selects left to right thus only giving 2nd and 4th. Worth checking propModerator edit by: cadguy Link to post Share on other sites
VR6gaz 0 Posted May 17, 2007 Author Report Share Posted May 17, 2007 cheers lads its sorted now it was a bolt in the linkage local garage fixed it for £20 he cant beleive it! he was expecting it to cost just a bit more than that n so was i to honest Link to post Share on other sites
