Guest dannysvr6 Posted April 17, 2007 Report Share Posted April 17, 2007 can any ne help just recently bought a vr6 and notice some water leaking on the ground under the front of the engine any ideas where it could be coming from its not much and its just small amount ,just wondered weather it could be a common problem Link to post Share on other sites
rodney 17 Posted April 17, 2007 Report Share Posted April 17, 2007 need a bit more info m8is from the belt side and are you sure its not just a worn pipe??? Link to post Share on other sites
Guest simplyvr6 Posted April 17, 2007 Report Share Posted April 17, 2007 are the water pipes balooning ? Link to post Share on other sites
Guest awesome Posted April 17, 2007 Report Share Posted April 17, 2007 Hello, if you have topped up your water recently, make sure to open all heater vents inside and put your heaters on full with the radiater cap still off, and let it run for a few mins ... this will get out any air bubbles which will help to reduce pressure on any water pipes, then rev it up a bit and just look all around for the leek ... pipes do go, usually small holes and careful inspection should show something, like mine i had a very fine jet of water that evaperated due to the heat, so you need to see for yourself where it is while the engine is running, but make sure it has warmed up first, good luck. Link to post Share on other sites
kalv 0 Posted April 18, 2007 Report Share Posted April 18, 2007 I've got a similar leak which is dripping out the side of the water rail (runs along front of engine)just by the thermostat housing.. getting it fixed today.. Link to post Share on other sites
lee060 3 Posted April 19, 2007 Report Share Posted April 19, 2007 possibly the stat housing , tends to be a common one . have a gander and see if you can see any dried up collant or any wet'ness round there or the rest of the engine for that case .liam Link to post Share on other sites
